メインコンテンツにスキップ
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
20回答 すべてを表示
My phone was frozen in ice
I lost my phone a day ago n I found it in frozen in ice next to an ice rink and it wont turn on but I don't have a charger handy but I want to know wat I can do if it doesn't turn on when I find a charger?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Xavier Aquino, STOP!!!!! DO NOT EVEN TRY TO CHARGE IT OR TURN IT ON. Hope I got your attention :-). Since it was frozen in ice, treat it the same as you would treat any water damaged phone. By trying to turn it on or charging it in its current condition, you are running a very high risk of shortening out the logic board etc. Remove the battery and disassemble your phone using this guide. Clean every part, including the connectors on the board as well as on the cabled with 90%+ isopropyl alcohol and a soft brush. Be diligent about it and clean it well. This does not mean to scrub hard, just rinse in alcohol often. Check for any burned looking or missing components.After that replace the battery (not an option but a must), reassemble it and re-evaluate. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Xavier Aquino さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 469
