Solder DC in directly to the connector board of Bose Soundlink 1?
HI,
I bought a Sounddock 1 Series and the Power adapter is dead. Those Adapter are expansive, and rather buying one I have a DC with same voltage +18V with 1A.
However the bos has a 4 pins connector.
Which one is positive and which one is neutral?
I have no way to test it.
Does my DC is suitable for this?
I know Bose power supply is +/- 18V 1A
Please let me know if you can help!
Many thanks
この質問は役に立ちましたか?
5 件のコメント
Is the diagram of the AC adapter plug or the Bose, socket input.
10Q
John Majer さんによる
Es ist jetzt ein paar Jährchen später, egal. Das Netzteil war tot. Das Gehäuse des Netzteils habe ich mit einem dicken Küchenmesser und Hammer vorsichtig geöffnet. Klinge in den Gehäuse- Schlitz und dann mit dem Hammer klopfen. Nicht hauen. Ging super. Die 2,5- A-Schmelzsicherung war durch weil ein Kontakt des Netzanschlußes sich freigenoddelt hatte. Kontakt verlötet, neue Schmelzsicherung rein, und tut. Seit zwei Tagen.
Frido Jester さんによる
I found a "Bose SoundDock Series II" box and inside it all looks perfect. It had no Bose +/-18V power supply, but I was lucky to get one for $20. Problem: it had the square 4 hole type of plug. So, I decided to solder the power supply cable directly onto the PCB. For that I dismantled its socket and at the same time investigated which pins go where. Can you please verify/confirm that my findings, before I turn on the power supply. I saw a diagram in which the outer ring was -V, the inner ring +V and the center ground. Here's a photo of the PCB's power input section.
Joh Drinda さんによる
https://app.box.com/s/sr0tzn7a4fc8vqp46s...
Joh Drinda さんによる
me sirvio bastante este post con el tema de los pines del conector ,finalmente construí un adaptador con un lm 7818 y un lm7918 que me entregan 18+ y 18- y mi sounddock funciona de maravillas
elias ronald quispe ramos さんによる
