メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
締切られた回答
Can you help me with the PCB layout and BOM
Hi , I'm attempting to repair a repair for a friend of mine. They let some one replace the screen for them and since then it's been having issues. He gave it to me to look at and I've noticed a resistor/capacitor has been knocked off near the Screen cable connector amongst other things. I'm capable of repairing this if i can find out what the value of the part is and preferably what it does.
If possible I'd like the PCB layout , schematic and the bill of materials.
Thanks in advance for any help
Tom
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
That is a tall order. All the stuff you are looking for is available with a few google searches. It is just not good to share those on here. Apple may have some issues with that since they feel it is copyrighted material:-) Consider posting a couple of images with your question of the area where the part is located, I am sure we can help you out.
さんによる
Sorry , forgot to add a pic.
Here is one , sorry about the quality. The right hand side circle is where the missing component is. The left hand side circle is where a PCB mounted But used to be. There's 2 of these missing from the PCB. Will this matter?
Thanks for your reply
さんによる
PCB mounted NUT not but!! Not sure of the technical name..
さんによる
コメントを追加
1 件の回答
ベストアンサー
tom hingston, from the angle of the picture it is hard to see what part you are missing . I attached an image with some of the components marked.
Reference designator DZ3 6.8V-100PF Zener Diode in a 0201 package
Reference designator FL13 80-OHM-0.2A-0.4-OHM Filter in a 201 package
Reference designator FL14 70-OHM-300MA Filter in a 1005 package
Reference designator DZ4 6.8V-100PF Zener Diode in a 0201 package
Reference designator C156 56PF 16V 5% 1005 package capacitor
Reference designator C124 56PF 16V 5% 1005 package capacitor
The "nut" that used to hold the board is a standoff 2.4OD 1.0ID 1.27H-SM
Hope this helps, good luck
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Brilliant. It was C156 I was after. Just have to hunt around at work now looking for that cap.
Thanks for your help
さんによる
Thank you for accepting my answer. Best of luck to you.
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 491
