メインコンテンツにスキップ
2011年初期のモデル。モデル番号はA1278 / 2.3 GHz i5 or 2.7 GHz i7 プロセッサー。
782回答 すべてを表示
締切られた回答
Best Options for Internal hard drive and RAM?
Hi there! I am totally new to this but I have taken a look at the videos and some guides for upgrading the hard drive and RAM and it doesn't seem to be overly complicated.
I want to upgrade the hard drive and RAM and I have a budget - no greater than $400. For the RAM, I have found this but Apple claims the MBP can only support up to 8GB RAM though the Youtube video showed the 16GB RAM working fine.
As for the hard drive, I have been looking into Solid State Hybrid Drives as from what I know they're not as expensive as SSDs but provide better performance than normal hard drives. I have came across this though the RPM is 5200RPM.
I generally want the best value. The RAM at 16GB seems a lot to me and I am not sure if 8GB would be a better answer. I only use the computer for school work and no photo/video editing and I do have many tabs in Chrome open (some of which are youtube videos) and multiple word, powerpoint, excel windows open at the same time. So if 16GB of RAM will mean noticeable increased performance then I'm all in.
As for the hard drive, I am unsure if that is the best option.
Thanks for any future help!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
The best bang for your buck in computer performance comes from Maxing out the RAM… provided you keep 15% of your boot volume empty (aka "free space") for VMEM and swap (temporary) files.
Yes many have found that you can safely run more than their "recommended" maximum amount of RAM. Stay within this guide's recommendation as you have planned -do not mix speed(s) or vendors (manufacturers of RAM) for best results.
The drive you propose should work with no problems.
If this answer is acceptable please remember to return and mark it.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Alright I assume since the guide you mentioned says 16GB in indeed the max RAM then I will choose to upgrade my MBP to 16GB RAM.
As for your comment regarding mixing vendors, will I be safe if I chose the hard drive I mentioned in my original post (http://tinyurl.com/l4hxntu) along with this RAM?
http://tinyurl.com/onnk3at
さんによる
Yes That is what I tried to explain.
さんによる
Alright I'm going to get the RAM and HDD I mentioned. Thanks a lot! I might have more questions in the future so I might ask again in the future :D
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 1,807
