メインコンテンツにスキップ
1.83 GHz Core Duo or 1.83, 2,もしくは2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
201回答 すべてを表示
締切られた回答
Not powering up, no power light coming on, no spinning drives
My 17" iMac 1.83 GHz Core Duo or 1.83, 2, or 2.16 GHz Core 2 Duo (EMC 2104/2110/2114/2124), would not start up after shutting it off one night. I checked the power outlet to make sure that wasn't the issue. I checked the power cord, by using another which I knew works, no luck. No power on light comes on, no spinning hard drive noise, power button doesn't feel like it clicks - just kinda feels dead.
I am hoping that it is the power button or a connection that is loose, not the power supply. Thankfully the iFixIt store has the power supply and many other supplies I may need.
Will update when the kids aren't around for an afternoon so I can pull it apart without fear of the parts not going missing.
Suggestions are very welcome! Haven't pulled apart a Mac before because mine have been so rock-steady (until now). :(
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Before buying installing parts - look at the LED diagnostic lights - these will point straight-off to power supply issues.
If this answer is acceptable please remember to return and mark it.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 186
