メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2376回答 すべてを表示
締切られた回答
Wont sync or charge even after dock replacement
To begin i had a Iphone 4 Gsm model A1332 that was not charging (it would charge if the phone was shut off) or syncing (nothing recognized it tried 4 different computers and different cables on all of them ) and after research i decided to replace the dock connector. I followed the ifixit instructions step by step and noticed that the dock had water damage indicator was red but no other parts had the indicator set off. So after I replaced the part i have seen no change.
ps I double checked all the connections and they are snug and all other functions work.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
and forgot new battery too
さんによる
コメントを追加
1 件の回答
I would try a another dock that is known working and try it in your phone if that doesn't work the water damage has probobly destroyed a component on the motherboard but before all that I would clean the motherboard with 99% ISO alcohol you could also try a new battery just to rule that out
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 117
