メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
締切られた回答
Non Responsive iPhone 4s - possessed
Touch screen is non responsive / but if I continue to hold the icon or word - it will eventually go to the next screen. In other words it would take you over 2 hrs to setup the iphone after a factory restore - that's if it didn't automatically put you in a diff. language by default. It has a mind of it's own!!!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント:
I have the exact same problem after just a screen replacement. The Phone boots up, normally, however i cannot slide the button on the screen to open it - the screen is unresponsive. It is my sons phone, and I cannot sync it from iTunes since it needs a response from the phone, which i cannot do, since it is locked... I cannot change the time and date in the phone in order to get it out of the searching mode ... do I order a new screen now just to check if this the problem ?? please help, best regards Rene
さんによる
If you are positive the screen connectors are seeded correctly then yes the screen is faulty
さんによる
コメントを追加
3件の回答
Try an hard reboot : hold power and home button --> Apple logo,
or restore it with iTunes..
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Done that been there at least 10x - also cleaned all contacts and reseated them at least 4x... inspected logic board - don't see any chip damaged and no water damaged either!
さんによる
コメントを追加
Sounds like the digi has gone bad. Try replacing it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Just replace the the screen and she will work no problem
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 164
