メインコンテンツにスキップ
General Electricカメラというブランド名で販売されたGEデジタルカメラの修理ガイドと製品サポート
when I turn on my camera it says lens obstruction
Ok so when I try turning my camera on it says lens obstruction and the lens wont come out and after awhile it turns off.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 11
9 件のコメント
I had experince too
さんによる
My camera brand GE 14.1 megapixel E1450W
さんによる
i tried to turn on my kodak pixpro az252 and it says lens obstruction and turns off how do i fix it
さんによる
Mine is a BRAND NEW Kodak PIXPRO AZ252 Bridge Camera. I had just opened it the day I bought it and it said lens obstructed Restart camera and then it shut off. I am really mad. The shutter and lens does not even come out.
さんによる
Same how do you fix it I have the FZ41
さんによる
4件以上のコメントを表示
コメントを追加
1 件の回答
ベストアンサー
Juanita Gonzalez, this is most likely caused by a stuck lens. These errors are more common with an extended lens, but can also appear in a retracted lens. Take a look on here to see how to deal with it. It will be the same for most brands. If this does not work, you may be looking at replacing the lens itself. Since you did not tell us what model your camera is, we can not provide any further details with that. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 4
11 件のコメント:
my camera is a kodak easyshare c195 14 megapixel with 5x optical zoom.. any tips??
さんによる
Mine is a Kodak Pixpro AZ251, and I know I deopped my camera, and after I dropped it It said lens obstruction, restart camera. what do I do now?
さんによる
Im having the same problem with my GE X500 Camera..pls need a solution .thank u
さんによる
i have the same camera with the same problem
さんによる
my camera doesn't work and it always says that lens obstruction. what should i do?
さんによる
6件以上のコメントを表示
コメントを追加
回答を追加する
Juanita Gonzalez さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 12
過去 30 日: 63
今までの合計 21,420
