メインコンテンツにスキップ
GSM iPad 2は16、32、64GBの容量オプションがあり、Dual Core A5プロセッサが搭載されています。モデル番号はA1396。修理作業は複雑で、ヒート(熱)を当ててこじ開ける作業が必須です。
20回答 すべてを表示
ipad 2 - My screen is blue after falling.
Hey guys, i dropped my ipad 2 on a carpet from 45cm. it has a screen protector but now my screen is blue but i can still see and interact with the display. (see photo)
what do i have to check if it is broken or what do i have to change?
(maybe the lcd or the display cable or the graphic chip?)
i have an ipad 2 with wifi and cellular, 64gb.
please help me :) and sorry for my bad english.
Paul
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
2 件のコメント
It's a hardware issue. You need to go to the Apple store. By the way, there is other method to fix iPad blue screen of death. But the way can't solve hardware problems.
How to Fix iPad Blue Screen of Death
さんによる
So basically what you want to do if it’s all blue and there is no apps, you want to hold the power button for 10 or so seconds. If it does not restart then I suggest you take it to the Apple store. Also try to make sure everything was saved usually it is but you should make sure,
さんによる
コメントを追加
8件の回答
ベストアンサー
First try a hard reset by holding down the power and home buttons together for 10 seconds or so. If that doesn't work try giving the back of the iPad a firm smack. There have been cases where a fall like this jars the LCD cable loose and a firm hit to the back sets it back in place.
このアンサーは役に立ちましたか?
スコア 16
20 件のコメント:
Totally worked!!!!! So excited!
さんによる
this totally worked. Thank goodness.
さんによる
Crazy, but it worked.
さんによる
Crazy, but it worked. Meaning the smack worked.
さんによる
It worked! Your answer saved me.
さんによる
15件以上のコメントを表示
コメントを追加
You may need to open it up and re-seat the LCD cable. See this guide.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
The sack worked awesome thanks
さんによる
コメントを追加
LIke David and Brian suggest, this is the LCD connector. Smack will resolve it for awhile, but for a lasting repair open it up and reseat the connector.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I was working on one that did this without dropping it. The display did not show except for a flash when you press the wake/sleep button. I did the bump method on it after some research. It recovered to full bright clear display, then I opened it up and replaced the LCD cable and sealed it with Kapton tape. The cable was probably not bad but it was not expensive so I replaced it anyway.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
The smacking it totally worked! Thank you!!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I tried this also with mine after I dropped it and everything went red on mine...After the hard reset didn't work, I re-dropped it several times and it fixed the problem........thank you for the info......
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Just smacking the back haphazard will probably not fix the problem. You will need to smack it about four inches fro each side in the corner where the volume control is. That is where the connector is and smacking anywhere else will probably not work.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Yes, it worked for my ipad2. I just hit few times at the back side of ipad and it is working fine now.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thannnkkk youuuuu...the smack totally worked.
さんによる
コメントを追加
回答を追加する
Paul さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 19
今までの合計 44,765
