Which cable controls touchscreen?
Just replaced digitizer, all went well, booted fine, but touchscreen not responding. Do you know which cable controls touchscreen?
Ribbon #2. It can be kinda hard to get in place just right- make sure you hear it click.
このアンサーは役に立ちましたか?
and when i unglued the touch screen glass of touch screen ourselves ? What should I do ? when opened, can see perfectly bonded touchscren cable itself and not make contact with the touchscreen glass .What should I do ?
このアンサーは役に立ちましたか?
I hope you purchased the right part, Apple in their infinite wisdom made the connectors slightly different from 3G to 3GS.
It could also be that you bought a faulty part, the failure rate from eBay is quite high because the parts are usually factory seconds,
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 6
過去 30 日: 11
今までの合計 12,604
