メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
締切られた回答
Wi-Fi unstable, sometimes grey, sometimes no networks
Hi,
I have an iPhone 4S with some very strange wi-fi behavior.
The phone sometimes has the known problem of greyed out wifi, but after the next reboot it'll suddenly enable the wifi switch. Although it is enabled it won't find any networks, then all of a sudden it does actually find and connect to networks... It's very hard for me to conclude what the actual issue is here. I've tried everything concerning rebooting/resetting.
It seems to have a lot of trouble with everything connected with the wifi... even opening the wifi menu in the settings sometimes takes ages even though it works sometimes.
Can anyone advise me on my next steps other than heating or freezing the phone which has proven to be a temporary solution in most cases..
Thanks in advance!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
You need to get the wifi-module on the logic board replaced or reballed(probably cheaper with a replacement chip than reballing it)
Any attempts to heat or freeze it will likely make the problem worse as the chip will only retract further. Chip replacement or reballing will likely be your only solution.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
Hi,
Yes, Anders is absolutely right. Try this: when you can't enable WiFi switch in the menu, check the WiFi Address (Settings>About>). If you see "Not attached" this means problem with WiFi module. And in the same time you will have a problem with the Bluetooth.
WiFi module replacement is a very difficult operation. You need a good service technician.
Regards.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 524
