メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
締切られた回答
When I removed the battery contact clip I pulled 4 pins off?
I was replacing the battery on my iPhone, following directions, and when I went to remove the contact clip four of these pin came off. They seemed to be sautered on the motherboard. I have read about this problem before, others ripped off the pins as well as metal squares too. I think that in the ifixit directions for a battery replacement, something needs to be added warning fixers, "be extremely careful when detaching the contact clip, so you do not damage the motherboard.
**Photos attached
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
I don't see pictures. But did you pry carefully and remember to unscrew stuff? If you did rip connectors off then you need to have mad skills with soldering to repair it, although I have seen people advertise that they repair it on ebay (don't know if they are good though). If you fix the images, I can be more help.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I have re-uploaded the pictures. yes I remembered to unscrew stuff, but I might off pried to hard.
さんによる
the solders are clearly broken, so if you don't have the necessary skill (or desire to learn), you are pretty much limited to paying someone else to fix that issue. sorry to bring the bad news
さんによる
コメントを追加
This isn't hard for a professional to fix--eBay $30
Feel free to contact me if you'd like some tips to try it yourself.
Jessa
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 161
