メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
締切られた回答
home button doesnt work after multiple fixes
My power button went bad a while ago. when I replaced it, it worked. but then my home button stopped working. I noticed that the two gold connectors were bent from me opening it so I replaced the lightning flex cable. Still no home button. so I finally replaced the home button flex cable and it still doesn't work. What can I do??? ive replaced everything I can to get it to work and it still doesn't work!! HELP!!!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
6件の回答
最も参考になった回答
If you open up and leave screen and all connected and press power to make phone sleep don't turn off.. Now with a screw driver touch the two metal prongs with the metal shaft at the same time this should light up your screen as if you were pressing the home button and will tell you that the part is working.. Do this first and report back
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
If you touching the two conectors with metal and it's not accivating the screen the try a new charging port it makes contact with the home button..
さんによる
コメントを追加
Do what con says. Also, does it feel normal? What happens when you press the home button? if it does not spring back up, you might be missing a tiny, but important metallic square that goes on the back of the home button
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
My home button doesn't work so i replaced the ribbon cable, still no joy. However, if I press on either side of the home button while pressing the home button it works!
Maybe see if that makes the home button work?
If so, how would you fix that?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I tried what Con suggested and didn't have any luck. I replaced my battery last night andd since then my home button wont work. I tried bridging those two connectors and it doesn't do anything either. Any idea what else it could be?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Yes, when replacing your battery, you must have pried between the battery and the logic board, just next to the sim slot. This is a common mistake that causes damage to components in that area that control the function of the home button and also of the power button.
さんによる
コメントを追加
If you actually made a good connection between the two leads, it's more likely that you have an open filter ( acts like a fuse) in the logic board.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
how do you fix the open filter ???
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
You replace it.
さんによる
well, bit more specific please :-)
Where do i find it ? easy to replace or fideling like heck with solderingiron ???
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 7
今までの合計 436
