メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
Front facing camera freezes, not working!
Hi,
I keep reading the great solution for the iPhone 4 front facing camera issue after screen replacement, but nothing fo the 4S.
I did a screen replace on a 4S, switching also from white to black. Since then, the front facing camera just won't work. When I switch form the rear camera to the facetime one, i just get a blurred image from what was on the rear camera, but nothing active on the front facing camera.
I read about a small jumper that may have gone missing on the 4 version, but is there a similar jumper on the 4s that could have broken off? All the 4 version photographes are - of course- totally different from what I see on the 4s mobo. I already replaced the camera, but nothing still.
All help is greatly appreciated.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
最も参考になった回答
The little jumper on the iPhone 4 when it goes you can't see the camera what so ever it would be stuck on camera shutter.. Was going to say change the camera but u have done that .. I would check u haven't damaged the pins on the motherboard
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I was wondering if there had been a solution to your dilemma. I too have the same issue with an iPhone 4s
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Nothing yet then has anyone got a solution for iPhone 4s front camera fix
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Eva Tahon さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 3,272
