メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
BIG problem iPhone 5 recovery mode
Hello guys:)
big problem here with an iphone 5, after power button replacement it asks a restore by displaying a recovery mode (itunes logo with cable) wel... the problem is that after the SUCCESSFUL restore, it doesn't turn on and it shows me again the recovery mode. I mean why? any suggestions? it could be an hardware problem? thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
thanks man, but as you mai know this function is already in tinyumbrella and of course already used :-) it just kick me off the recovery mode but then it reboot in recovery mode again...
さんによる
I REALLY DON'T KNOW WHAT TO DO!!
I TRIED EVERYTHING POSSIBLE IN MY POSSIBILITIES AND KNOWLEDGE...
- Created a IPSW to enter DFU mode with tinyumbrella and than restored... NOTHING again recovery mode.
- TRIED to fix the recovery mode with the tinyumbrella "tool" NOTHING.
etc. etc...
PLEASE, if you have any other SERIOUS suggestions and some advanced trick let me know!!!!
さんによる
コメントを追加
5件の回答
最も参考になった回答
Step 1
Download and install the latest version of iTunes if you do not have it installed on your computer. Launch iTunes after it is installed and updated.
Step 2
Plug your iPhone into your computer using the USB cable and click "OK" on the alert window that informs you iTunes has detected an iPhone in recovery mode.
Step 3
Click on the name of your iPhone in iTunes and click the Summary tab.
Step 4
Click "Restore iPhone" and then "Restore" on the alert window warning you that all your data will be erased.
Step 5
Click "OK" when the restore process is complete. Monitor the progress of the restore by watching the progress bar. The restore may take some time, which is mostly due to downloading the iPhone software image. The image is a large file and the download time depends on your Internet connection speed.
Step 6
Restore your iPhone data from a backup file in the "Restore from this backup" drop-down list and click "Continue." Optionally, you can set up your iPhone as a new iPhone and backup from an iCloud backup.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I would try recboot, it's great at getting stuff out of recovery mode.
http://download.cnet.com/RecBoot/3000-18...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Connect iPhone -- hear connect beep.
Hold down power and home until you hear the disconnect beep.
Let go of power but keep holding home until you hear a connect beep again.
At this point, the screen stays black, Windows detects unknown USB device and starts installing a driver, and once the driver installs, iTunes should report an iPhone stuck in recovery mode.
If that doesn't work -- have you tried a new cable by using iPhone Data Recovery?
And if that doesn't work, then it's probably time for a visit to Apple.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
It's not uncommon to see that iPhone stuck in recovery mode. To get your iPhone out of recovery mode, follow these steps:
1. Hold down the home and power button for about 15 seconds, this shuts off the iPhone.
2. Press the power button to boot the iPhone."
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Most likely broken chips on board!
When phones off plug in lighting cable to power on then quickly disconnect as it powers on you should now be able to start up
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ulpiat さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 645
