メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
1903年に設立されたイギリスの自動車メーカーが製造する自動車の修理ガイドとサポート。
change indicator relay on Vauxhall Combo
My right hand indicators don't work properly and I have been told that it is probably the relay. And wouldn't you know it, apparently it's a real pain to replace? Because of its location. Apparently it is behind the battery and something else. Any help please.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
6 件のコメント
What year is your Vauxhall?
さんによる
It's a 2005 55 plate
さんによる
Does that relay also control the reversing light?
さんによる
any more my light do not work 1.9 vauxhall combo reg 04
さんによる
I have no flasher and hazards . Fuse and relay is ok on vauxhall vivaro 2004
さんによる
1以上のコメントを表示
コメントを追加
2件の回答
最も参考になった回答
Geoff Heyes, the relay is located under the hood, adjacent to the battery. You should see a black weather sealed box. You will need a long extension and a Torx ( I read a T20) socket to remove the cover. The indicator relay is the large yellow one.
画像
画像
information from here
このアンサーは役に立ちましたか?
スコア 2
6 件のコメント:
That's a great help.
Many thanks.
Geoff
さんによる
You are welcome, best of luck to you.
さんによる
This was really helpful to me many thanks
さんによる
Hello,
Thank you, this is super helpful, even now!
If you're able, do you have a replacement source for the info? I have the same issue with my indicators, and want to figure out what relay to buy...plus my wipers won't go max speed anymore, which I think is linked to one of these also in the rear fusebox. The manual I have doesn't explain any of them, sadly.
Many thanks in advance!
さんによる
@larn what exact year, model etc. is your Vauxhall? Let's see what we can dig up :-)
さんによる
1以上のコメントを表示
コメントを追加
This relay is located near the BCM module. It is located under the plastic that covers wiper linkage and motor. There is another plastic that covers BCM module and relays near it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Geoff Heyes さん、ありがとうございました!
統計データ:
過去 24時間: 9
過去 7 日: 36
過去 30 日: 152
今までの合計 34,751
