メインコンテンツにスキップ
An industrial gas-powered stove by Vulcan.
27回答 すべてを表示
wont go thru the gas I replace gas valve and the igniter
My vulcan gas stove wont go thru the gas i replace the shut off valve and the igniter nothing happen
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
4 件のコメント
Would you give us the model number and name?
さんによる
heres the model number 260l77r
さんによる
model 515-197
さんによる
If it has a gas regulator on it, check that. Sometimes the gas regulator screen will get trash in it.
さんによる
コメントを追加
2件の回答
ベストアンサー
Here's the operators manual: https://my.vulcanfeg.com/resourcecenter/...
The next link on that same page will give you the service manual.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
+ You have a pilot driven system in your oven. With the parts you have stated replacing the most likely cause of it not working are the size of the pilot light - adjustable from a screw on your temperature control valve - or flame placement on the mercury vapor switch (mistakenly called a thermocouple on gas ranges). The flame should engulf the mercury vapor switch closer to the center and towards the front of the sensor. There is a hollow tube that looks like a wire going from the sensor to the safety valve that puts pressure on a diaphragm in the valve to open it. If the flame is hitting on the sensor correctly you can feel a vibration on the hollow tube/wire when the size of the pilot light is enlarged by the temperature control valve, calling for heat. If the fore mentioned are all in order, your problem is with your temperature control valve.
さんによる
コメントを追加
incoming gas yes goes to a regulator that goes to a valve that is controlled by a safety valve that allows gas to flow to a burner that is controlled by a thermostat,sometimes controlled by a flame switch that goes to an orifice that regulates the size of the flame got that
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
jemson0105 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 12
今までの合計 3,998
