iPhone 4s white screen
My iPhone screen turned white and only returns to normal when pressure is applied to the top section of the iPhone. The LCD was replaced with a new one two months before this occurred.
It seems that the connector of LCD loosens or was screwed too tightly. You'd better reassemble it.
このアンサーは役に立ちましたか?
Take the emi shield off and place 3 layer of electrical tape on top of connector when u place the emi shild back on this will force the lcd connector not to move..
このアンサーは役に立ちましたか?
best fix would be install a new lcd.. bcz as far as my experience in fixing screens.. problems like this are not just loose connectors.. they are some missing screws and possibly damaged flex for lcd too..
RECOMENDED BUYING A NEW ONE FOR LONG TERM NO HASSLE FIX.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,336
The screen goes back to normal when pressure is applied to the top right hand side.
liam walker さんによる
