Why does my wireless connection keep cutting out
the wireless internet (wifi) keeps giving me a hassle. I need to keep doing a right click and resetting the wireless adapter about every 2 hours, sometimes sooner.
Mine also does this same thing, en even with resetting my router, it keep droping the signal, somtime within 10 mins of being connected, my other laptop keeps this signal all day with no problems.. Acer Aspire One AOA150- is the one that keeps dropping out.. the other is a tha dell latitude
このアンサーは役に立ちましたか?
its not your router, its ur Acer, tha wifi card is garbage
t seems like a WiFi channel conflict so all you need to do it to change your WiFi broadcasting channel. Open up your router`s setup by entering the default gateway IP, enter username password if prompted ->go to WiFi or Wireless Lan setting and make sure that broadcasting is b/g/n mixed mode, then check what broadcasting channel is selected starting from 1 to 11/13, in case of extreme start or end make in middle like 6 or 7 and in case of any middle number like 6 to 8 make it either 10 or 3. By changing the broadcasting channel shall hopefully stop any interference with other frequencies. for more help and support visit www.acer.com/wireless.help and i hope this will help thanks
このアンサーは役に立ちましたか?
Choose the right type of wireless router with 10.0.0.1 IP address as a default gateway and so you can meet your needs in a hassle free manner. Resolve any kind of logging issues with the help of online guidelines.
More info find here: http://bjfscj.net/the-important-steps-to...
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,557
