メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The HTC One X is the first HTC phone to be equipped with a quad-core processor, released in April 2012.
Phone is ON, But screen no light
my phone delays to switch on and it also does not show anything on the screen it's in dark mode no back light
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
4件の回答
最も参考になった回答
Hi,
If you have data backup try wipe data / factory reset.
But for back light maybe this is hardware problem - display or part of main board...
Regards.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
It sounds like the back light for your phone may be broken. While it's not easy, replacing the screen/digitizer may solve your problem.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I had a phone where the phone was on, but the screen would not turn on. The Power Button has a little black button attached to the top of the cable that wraps over the top of the phone. It had fallen off the phone so the power button no longer made the screen come on.
I pulled the phone apart, and luckily the Little black button was in there loose still. I cut a piece of tape and stuck the black button on it before placing the tape over the cable, and putting it back into the phone. The phone screen powers on again when pressing the Power Button.
This may not be your issue by the description of your problem, but the title of your problem makes it sound like this could have been you issue.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
what is the orange bendable thing with a flat middle peice on the circuit
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
ibrahim さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 6
過去 30 日: 16
今までの合計 2,476
