Why does the top agitator not move and the washer stops?
the washer fills but the top agitator doesn't work and the machine shuts down in mid wash.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Agitator Repair Kit
If the washer won't agitate this agitator repair kit may solve the problem. The kit contains the components that wear out over time. This is a relatively easy repair.
Drive Block or Bell
If the washer won't agitate the drive block or bell might be worn out or broken. The drive block connects the washer transmission to the agitator, if it's worn out the transmission shaft will still move back and forth but the agitator will either stay still or move slightly.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 241
1件のコメント
does the agitator work at all? Does it work in any cycle? what make and model is your washer?
oldturkey03 さんによる
