メインコンテンツにスキップ
Samsung Galaxy S4はモデル番号i9505、13メガピクセルの背面カメラ、5インチ 1080ピクセルのディスプレイを備えています。
526回答 すべてを表示
Same glass on the S4 Active as the S4?
I have a S4 Active and am not finding much information on ifixit for the device. I broke the glass on my phone and would like to replace it. The LCD still works. Does anyone know if the S4 glass is the same as the S4 Active? Can i buy the kit for the S4 and will it work on the S4 active?
Thanks in advance for the help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
5件の回答
I had the same problem and the shape of the standard S4 glass is different from the S4 Active because of the buttons. I've also read that the glass is different and that the glass can't really be replaced without the digitizer. I'm still learning as I go. I haven't found a glass-only kit. Only Glass + Digitizer
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
No, both glasses are different.
How did you open the S4 Active?
Thanks for your answer
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
how about lcd and digitizer are s4 and s4 active the same lcd and digitizer? I know front glass is different.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi NO Difinitely different. Not only that but you also have a back light on the s4 active like an iphone. So if you spray alcohol or glue remover onto screen without removing backlight you are going to damage it. Just desolder the backlight first...remove glue and replace the new screen
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
unfortunatly the s4 and s4 active arent the same.. you can only buy the lcd + digitizer assembly as one whole peice. which is a good thing really cause this means that the front of the phone is sealed and water tight, i think theyre about 90 pound to buy. which isnt that bad to be fair
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
mophats さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 3
今までの合計 3,388
