メインコンテンツにスキップ
AppleのiPad AirのWiFiモデルのバージョンはモデル番号A1474、スペースグレーと、シルバーがあり、カスタムA7プロセッサーが装備されており、容量は16、32、64、128GBがあります。
299回答 すべてを表示
Shifted smart cover magnets, easy fix?
It seems like the upper right smart cover magnet in my iPad air has shifted and is no longer functional.
I used to hear little clicks from my iPad Air whenever closing the Smart Cover or opening it so it wraps all the way around.
I eventually figured out that it was a magnet meant to hold the smart cover clicking when moving around inside the case.
After opening and closing the case several times, it seems the upper right magnet (near the camera) has shifted significantly enough to keep it from holding the smart cover in place while open and wrapped around.
The real issue, however, is that when closed, the rightmost part of the cover simply hovers above the panel!
The magnet must have flipped itself upside down.
No amount of messing about with the cover seems to get the magnet to shift again.
This isn't an issue justifying arduously opening the glued together panel in my opinion, so I wanted to know if there is any other way of repairing this?
I thought about taking a larger magnet and trying to shift the panel magnet back into place, but I'm worried about harming the electronics.
Any ideas?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
If it's an iPad Air it's under warranty you should take it back to Apple for a replacement.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Would if I could.
I don't reside in the US...
I've contacted the retailer from which I bought it but I don't expect that they'll be too helpful... Which is why I'm seeking an easy fix, if one exists
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
maly さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 12
今までの合計 2,806
