Should I junk my mac mini
My mac mini late 2009 3.1 has a damaged HD cable, damaged interconnect cable, and broken heat sensor wire. Is this repairable or shoud I just junk it?
Charles Nix, right now, having done a quick search, I found the Hard Drive Cable with Thermal Sensor for $6.95 and the Mac Mini Interconnect Board for 14.95 at powerbookmedic.com I am sure that there are more places that have the same price. So those are definitely cheaper than a new computer. Of course, you know to find the repair guides right here I would go ahead and repair it ....
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 4
今までの合計 180
5 件のコメント
Charles Nix, why would you. The cables are readily available and they should be a lot cheaper then a new computer. What are the last three digits of your serial number. With that we can properly identify your MacMini and can help you finding the cables. Is it just the cables that are damaged or is it the connectors as well?
oldturkey03 さんによる
Thanks for the quick response. Serial number is YM93712719X. The technician who looked at the MacMini said the HD cable was damaged and that the interconnect board plug was damaged. The heat sensor is disconnected and broken. He said he'd have to get a new hard drive from Apple, which doesn't seem right to me. I have a new HD I'd like to install, so I don't want to get a new HD from Apple. Thanks guys. This is very encouraging.
Charles Nix さんによる
I'm not sure if the interconnect board is damaged. The technician and I talked over the phone. I'm sure I could find out.
Charles Nix さんによる
These look like the specs for your computer
2.0 GHz Core 2 Duo (P7350)
Intro Date: March 3, 2009 Disc Date: October 20, 2009
Order No: MB463LL/A* Model No: A1283 (EMC 2264)
Subfamily: Early 2009 Model ID: Macmini3,1
Std RAM: 1 GB, 2 GB* Std VRAM: 128 MB, 256 MB*
Std Storage: 120, 320 GB* Std Optical: 8X DL "SuperDrive"
oldturkey03 さんによる
Thanks oldturkey03. I thought replacing the interconnect board (just the sound of it seems intimidating) was beyond me. I was lost, really. Thank you very much. I feel empowered and that may be a greater service than the money I will save.
Charles Nix さんによる
