メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
display replaced and... [NAND] _Findflash...
Hello, I changed the display of my iPhone 5, but when I turn it on, it appears this:
[NAND ] _FindFlashMediaAndKeepout :601 physical nand block offset 1
[NAND ] start :356 this 0x9f538400 PROVIDER=0x9f6b1f00 flashMedia=0x9f6b1f00
[NAND ] WMR_Start : 149 Apple PPN NAND Driver , Read/Write
[NAND ] WMR_Start : 174 FIL_Init [OK]
[NAND ] WMR_Open : 371 VFL_Open [OK]
[NAND ] s_cxt_boot : 88 sftl : error , unclean shutdown; adopted 11280 spans
[NAND ] WMR_Open : 420 FTL_Open [OK]
[NAND ] _publishServices : 642 FTL capabilities : 0x00000001
[NAND ] _ppnvflGetStruct : 3469 Checking borrowed blocks - count : 23 max_count : 23
[NAND ] _fetchBorrowedList : 881 number of borrowed blocks 16
and then it turns off... What can i do?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 23
2 件のコメント
I've seen some people say replace the camera flex? A few people have said this works. I have the same problem and am considering trying that solution.
さんによる
I spamed the force reset like three times before it cud read it and then it worked again
さんによる
コメントを追加
13件の回答
最も参考になった回答
There is something wrong with the front sensor cable, reattatch or replace the cable and try again
このアンサーは役に立ちましたか?
スコア 5
コメントを追加
Check out our blog post on this issue, their are several different issues that can cause it including the Compass/Accelerometer IC:
http://blog.irepairnational.com/2014/10/...
このアンサーは役に立ちましたか?
スコア 4
3 件のコメント:
I love you iRepairNational! I have seen your post here before, and just now remembered it when I needed it. I have an iPhone 5 here right now with water damage. I have replaced/reflowed all the connectors and put back everything that was damaged....EXCEPT the compass ic. Still booting up with NAND error messages.
This is one of those Eureka times where you can JUST TELL that replacing the compass ic will solve this. I can't believe I forgot this. Thank you!!!
Jessa
さんによる
Yup. Heavy corrosion under compass ic, removed it. Phone is working!!
さんによる
100% done thanks alot phone work good after reheat only
さんによる
コメントを追加
NAND errors are usually related to a flex cable problem. (And when they are not, it is the motherboard). If it wasn't doing this before your screen replacement, it is probably a flex cable. Try booting the phone with only the power flex installed and see if iTunes recognizes it.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
First you change new display and check if you face same problem again then you remove compass ic your problem solve in few minutes
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I reattached and still got the same error. I then disconnected both sensors to see if it would boot and once again got the same error. I ordered the new front facing camera and sensor flex cable. Do you think this will resolve the issue, or could my logic board be done?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Am I looking for iTunes to recognize it or not recognize it to tell if it's a motherboard issue?
さんによる
コメントを追加
Hi mate yeah same problem...SOLUTION: I replaced the display with a working display..obviously both displays were working but jessabethany was right. Its the front facing camera flex...either check it ifs all connected or just replace... Also the camera speaker and proximity sensor are connected through some pins that may require reflow of solder...theres about ten small pads..if these get loose its probably whats causing the error. i just replaced display to isolate problem and itunes restored fine...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
try it original screen
Update
try it original screen.and restart phone with power and home button.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
yes very true, the camera /sensor/ mic/ head speaker, ribbon cable are to blame for this, my suggestion would be restore without the screen, via iTunes then, after iTunes has finished turn off device, fit without that ribbon see if that works, if yes you know its a faulty camera ribbon etc... you can fit the one to the new screen, just remember to use the old head speaker/phone as well, i had an incompatibility issue so used my old, remember to fit it well as the sound will be terrible otherwise! thanks for your suggestions, prevented another phone going to landfill.. thank you!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
한국어로좀 설명안되나요
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
소수의 사람들이 여기에 한국어 이해하기 때문에 될 수 있습니까?
さんによる
나는 확실히 한국어 를 이해하지 못하는
さんによる
コメントを追加
I used WhiteOut after getting the NAND Flash display error and found it to be an excellent workaround. I've done this several times with both the iPhone 4/4S and 5. Special Note: The front sensors are all sensitive to visible light (proximity sensor, ambient sensor, etc.).
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
i have reheat u16 ic and all done device boot normally tested 100%
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Sensor flat cable is damaged, plug it off the motherboard and try restoring the iPhone (hard reset method).
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
In my case i need to dissasembly all flex cable to cameras, button, and headphones from MB
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
crikketto さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 17
今までの合計 44,687
