メインコンテンツにスキップ
Sony Xperia Zは2013年に発売されたAndroidベースのセルラーフォンです。Sony Xperiaの中では、5インチのHDディスプレイを持つ最も大きなモデルの一つです。モデル番号はC6603/C6602です。
98回答 すべてを表示
How to unfreeze phone?
While in record mode, my phone has frozen. How do I unfreeze it? I've tried turning the phone off, but nothing happens. I've tried taking the SIM card out, but nothing. How do I take the battery out of this phone? Will that work?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 165
49 件のコメント
Thank goodness almost thought I am screwed, you're awesome my phone is my mobile assistant imagine loosing everything as I cant backup every day, jeez thank you for the advise. LOVE YOU!!!!!!
さんによる
It worked, thanks for the help. It's good to have internet
さんによる
thanks it helped ,now its working
さんによる
this helped me my phone was frozen for three hours and i was freaking out it was frozen on a ugly seflie of me thank you so fing much
さんによる
its turned off now but everytime i try to switch it on again, it freezes again on the same screen
さんによる
44件以上のコメントを表示
コメントを追加
3件の回答
ベストアンサー
Try holding the power button and volume up button at the same time, until the phone gives three short vibrations. Then it will turn off, and you should be able to start it again as normal.
このアンサーは役に立ちましたか?
スコア 455
254 件のコメント:
thank god I found your answer, I was already afraid I'd have to completely reset it, since all the other websites and stuff suggested doing so. Who would've thought it's that easy. Really, thank you so much, this saved me a lot of trouble.
(I also casually made myself an account just to tell you about my absolute gratitute hahah yeah)
さんによる
DUDE!!! LIFE SAVER!!!!! It happened to me while taking pictures, Worked like a charm! Awesome!!
さんによる
dude you're awesome ,thanks
さんによる
OH MY GOODNESS THANK YOU!! I took it into Bell today and the guy said i was S.O.L and would have to get a new phone! Its not even a year old! I was furious!!! Thank you SOOO much!!! So much good KARMA please to go your way! xo
さんによる
really it works! it's been 7 hours since my phone stuck up, can't turn off.. and i just did to call my phone until it will become battery empty but i'm so !@#$ tired waiting,, thank you!!!
さんによる
249件以上のコメントを表示
コメントを追加
It didn't work for me but this did (I got this answer from another website)...
All you need to do is a simulated battery pull
A simulated battery pull will simply tell the phone to reboot, to turn itself off and then back on. This simple tool is amazing for a frozen or locked up Sony Xperia, or if your phone is showing a white/blue/black screen, if it’s having navigation problems, or for any reason you can’t seem to power the phone off yourself all you need to do is the simulated battery pull.
To do a simulated battery pull on a Sony Xperia you basically follow the same steps as you would when doing a simulated battery pull on the Motorola Atrix HD, all you have to do is hold the Volume Down button and then the Power key and hold these two buttons down simultaneously for about 15-20 seconds. After holding them down for about 20 seconds if the phone didn’t power cycle then release the keys and try and turn the phone on like you normally would by briefly pressing the power button.
このアンサーは役に立ちましたか?
スコア 14
13 件のコメント:
Thank you roxsox, the simulated battery pull was the only thing that worked for me as well.
さんによる
yay now that 3orked ty!
さんによる
Thank you so much I was going so mad that I was ready to throw the phone across the room as I was trying what other people said but that still did not work but thankfully yours did so thank you again
さんによる
Yep that trick with the down button and power worked amazing..because when it froze on FB ..I could do nothing.. it is a sealed unit... I was bit worried.. Thank you
さんによる
The screen comes on but just blue with scrolls wave ....no icons
さんによる
8件以上のコメントを表示
コメントを追加
Your phone screen could be broken, even with no cracks.
You could get it checked and see if it needs a repair.
Not sure…
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
ty gilchrist さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 23
過去 30 日: 56
今までの合計 277,461
