メインコンテンツにスキップ
Model M8413 or A1007 / 600, 700, 800, or 900 MHz G3 processor
36回答 すべてを表示
Thinks there is an external monitor attached.
I inherited an iBook G3 14" (700Mhz) and installed Tiger and updated to 10.4.11. Now, every so often like the fabled dripping water torture, the screen goes blue for a couple of seconds as it does on my MacBook Pro when I attach it to a projector. Also, when I click on the menu bar "Displays" icon, there is a ghost VGA monitor with resolution settings showing up alongside (well, under) my Color LCD's settings.
I've just tried attaching the Apple VGA adapter a few minutes ago to see if that would stop the switching and so far, so good but I'm not exactly hopeful. Has anyone else had this problem? Any fix other than what I hope will work with attaching the adapter?
(btw, the adapter is not attached to any other cable or monitor)
Help...
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
It might be a good idea to take a look at the display, and check if anything is loose or disconnected. You may also want to try with an external monitor and see if this problem persists.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Christopher さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 1,005
