moving mouth no voice
I bought this furby one month ago she has stopped talking but still has eye and body movement. can she be repaired?.
alisha, here is my answer to a very similar question "I would get to the "tummy switch" and check the circuit from there. You do have a couple of choices here. Check the switch, then the speaker. Check the connector for both. You will need a multimeter to check those. Follow the schematic to work on your Furby's voice, and check on here for directions on how to skin the Furby. Hope this helps, good luck.
このアンサーは役に立ちましたか?
Yes, these Furbys are called Mutes. I would advise to find a donor furby of the same year, and interchange the speakers. I know on Ebay they sell tons of Furbys that are used for parts.
Here is a site that might help: http://www.adoptafurby.com/furbyinfo/spe...
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 669
