メインコンテンツにスキップ
iPhoneの第2世代モデル。モデル番号はA1241 / 8 もしくは16 GBの容量/ ブラックもしくはホワイトのプラスチック製背面ケース。修理はオリジナルiPhoneに比べて直接パーツに作業ができます。ドライバー、こじ開けるためのツールと吸盤カップが必要です。
1158回答 すべてを表示
lock button failure
I need to troubleshoot why my screen isn't working after A took the working headphone jack from a iphone 3GS and installed into an Iphone 3G. It all went together smooth but when I got to testing, I tested with the screen not latched all the way so if it didn't turn on it would be easier to remove. well it turned on but when i started to click the screen in place one of the #1 or #2 stickered ribbon cable connections came unlatched and the screen went black. I thought, no problem I would re hook up and turn on and the screen would work but it hasn't.
I have let the battery run out (it was dead to start so didnt take long) and removed and reinstalled the screen, plugged into charger and it still makes the ding like it is booting up but it doesnt show apple logo or anything.
Any ideas on something I can do, check, or replace?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
1件のコメント:
I just plugged it in again and this time it gave me a white screen, I kept it on the charger longer and it loaded up after the white screen like it should, the only problem is the problem that I was trying to fix the first time, the lock button doesnt work, I already salvaged the headphone jack from another broken iphone of the same version, any ideas where to look next?
さんによる
コメントを追加
1 件の回答
You can get replacement parts from apple but they will be $100-$200 never got replacement parts thow sorry.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
さんによる
コメントを追加
回答を追加する
Eric H さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 3
今までの合計 75
