メインコンテンツにスキップ
The Sony Cybershot DSC-W55 was released in early in the year 2007. It is upgraded with a 7.2 megapixel camera compared to the previous model's 5.1 camera and has 56mb of internal memory.
23回答 すべてを表示
no Lcd backlight, the cable is damaged
Hi.
My camera's LCD is correct working,I can see things on it difficult. it's backlight cable is damaged and I don't have light under the LCD. how can I repair it?
my camera is Cybershot DSC-W55
can any body help me?
my English is not so good, I can explain more clear if you want..pleas help me :(
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
shiva, the backlight and the LCD are mounted together on this camera. You will have to replace the complete LCD to get your backlight fixed. Here is the guide for it. Hope this helps, good,luck.
このアンサーは役に立ちましたか?
スコア 1
7 件のコメント:
tnx for answer.
I replaced the LCD! LCD and backlight! but my backlight is cut off and now it is not join to the that green board!! can i join it again by glue?
さんによる
You mean the cable broke or is torn?
さんによる
The cable is completely torn.. you can see my camera in these pictures.
http://upload7.ir/images/517939789278350...
http://upload7.ir/images/848897815152726...
the backlight cable is torn. :( can i repair it?
さんによる
Sorry, but it does not look like you can fix that ribbon cable. You will have to replace the assembly.
さんによる
and new question!
how can I test the inventer?? can you show me where is the inventer in this camera?? what is it like? I dont know is it works good or not!! how can i know?
さんによる
2件以上のコメントを表示
コメントを追加
回答を追加する
shiva さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 558
