drum not moving on any cyle
my beko wfe7247w washing machine is going through full cycle but the drum not moving. belt fine
is the motor pulley spinning? if yes check the tension on the adjuster. if not take a volt meter and check power at the motor. if power is there replace motor. if no power there is a fusible link that supplies power. check for power before link. if power is there replace fusible link.
nick
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 8
今までの合計 171
