メインコンテンツにスキップ
15.6", Intel HD Graphics, Core i3 2330M, Windows 7 Home Premium 64-bit, 4 GB RAM, 500 GB HDD
58回答 すべてを表示
締切られた回答
Cant Install Windows 7
i need help with installing windows 7 on my laptop i am doing a custom install with the cd that was given to me from dell and i erased my hard drive i formatted it and then i click it and i click install then it shows copying windows files and other stuff and then i got the error at the bottom 0x8007045d i am trying again to see if it happens again
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Hi rock,
I had an issue with a Lenovo T34 some time ago installing Win7. It simply did not work from CD - and reset during initial installtion. After i created a bootable flash drive the same installation worked perfect.
One could suspect CD driver buffer issue, or timing issue with slow CD drive.
Try installing etc. Linux Mint, from a flash stick.
Use http://www.pendrivelinux.com/boot-multip...
for an easy way to make the thumb drive needed.
If that works, then you should use flash stick instead of CD with Win7.
Best of luck Carsten
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Better link for linux distro til USB
http://www.pendrivelinux.com/liveusb-ins...
さんによる
コメントを追加
try using a external drive that may work if you are having trouble with the built in one
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 7
今までの合計 1,541
