left trigger connector broke off logic board
Made a mistake trying to fix my psp go and made it worse, L trigger no longer works, any way to reattach connector to logic board?
aaron, the angle of the pictures is a bit distorting. It appears as if your solder pads are still in place. I would resolder the connector. You will need a good soldering iron with a small tip to accomplish that, but not impossible. If you are unsure on how to do it, any decent electronics shop should be able to fix that for you. Hope this helps, good luck.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 1
過去 30 日: 7
今までの合計 469
1件のコメント
Thanks everyone for the help I really appreciate it, i am kind of new to all this and i apologize for being uninformative. You all were a great help! Thanks again!
aaron さんによる
