メインコンテンツにスキップ
ホリデーシーズンを飾ってくれるライト。
26回答 すべてを表示
Half the string is out
We have the first version of LED's that Costco sold about 7-8 years ago. They do not have replaceable bulbs because they are all molded into the string. No sockets.
Some bulbs have 2 wires and then in the middle where the burn starts that bulb has 3 wires.
How can I fix these?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
Noma does not give appropriate directions on the maintenance of their string lights. Example they provide a spare fuse but no instructions on installing that spare. The string recepticle is the logical location but it appears to be difficult to open without destroying the casing. This begs the question why bother providing the fuse. BTW my string light is one years old.
さんによる
コメントを追加
1 件の回答
ベストアンサー
i've never worked with that brand of lighting before, but usually with christmas lights, the are all interlinked as a loop circuit, so the first one that is out is usually the cause of the problem... as the link cannot carry on further than the busted bulb. i'd try and replace the first dead bulb, or if you can't find replacements, you could try just linking the connectors by shorting them and taping it up so the rest of the lights can be turned back on.
But thats just a suggestion, as i don't have much lighting experience
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Bill さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 21
過去 30 日: 68
今までの合計 52,841
