メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2375回答 すべてを表示
Replaced battery won't work, stuck in boot loop
Ok, so my iPhone battery has become progressively worse over the last couple of months(or so..) so i thought it would be smart to replace it! but i didn't want to do ship it to an apple store and pay loads of money for them to do it, so i bought it myself. i opened the phone today, unscrewed the philips screw holding the battery connector in place, and the started trying to get the battery out, but it was really stuck in there, so it took a while to get it out, even had to put some guitar picks(thin) in there(but not where there was any cables
though). i finally got it out, so i simply put in the one, connected the cable, and then i tried to turn it on(with wall charger in of course), but it turns on for like 5 seconds, then turns off again(boot loop). i have reconnected it several times, and i tried to boot it without battery, and the same thing happens(boot loop). so i have no idea of whats wrong here, and i really don't think i have damaged anything in the process!
thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
3件の回答
is the replacement battery an OEM (from Apple) or is it a generic one? It could possibly be a defective battery. did you put the original battery back and see if it doesn't do the boot loop? if so, then you know the replacement battery is incompatible or defective.
Hope this helps. good luck!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Try to turn it back on with the rear case off
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
if the above both methods didnt worked.
try changing the bottom charging dock aswell.
bcz if thats not hardware fault (considering u havent broken anythng) then it should atleast boot without battery..
but its not doing that too so its posible botom charging port or battery or something on the board near battery connectors..
good luck.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
EndreI さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,027
