メインコンテンツにスキップ
Mac miniは、2005年1月22日に発売されたApple製最初の小型フォームファクタのデスクトップコンピュータです。Macintoshラインナップの4つのデスクトップモデルのうちの1つです。主にall-in-one iMacの代替PCとして使用します。
Superdrive HDD replacement not working
Hi
I've just worked through the guide to change my superdrive for an additional HDD. At the same time I also swapped the HDD for an SSD to boost speed.
Which ever drive sits in the original HDD bay seems to work perfectly (currently sending this via the SSD). However, the drive sitting in the superdrive replacement bay doesn't seem to come up on the desktop, or even be findable as far as I can tell.
I double checked that all of the connectors are snapped in (and they are as far as I can tell). Is there something I can do to find the other drive, or would it be possible that I need a new optical drive ribbon cable (or could to connector on the logic board possibly be an issue, in which case yikes!).
I don't know if the superdrive was working previously - I assume so as I bought the machine 2nd hand but in working order, specifically to swap it out.
Any help gratefully received.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
Hook up the superdrive and see if it works. If not then you have diagnosed your problem correctly and the cable needs to be replaced.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Thanks for this - I did just that and it worked perfectly. Turns out that the new drive wasn't engaged properly in the caddy. Thanks for your help.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Josh G さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 257
