メインコンテンツにスキップ
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548回答 すべてを表示
High Fan RPM, Crashes Often, No High Temps! Help!
I know this question may have been asked, but I've done just about everything I can. I have no warranty and I'm a first time Apple Computer. I've downloaded iStat and SMCfancontrol. CPU temps run at about 30-32 degrees Celsius and CPU fan runs at 3900rpm.
SMCfancontrol doesn't help,Ive tried SMC reset as well as PRAM with no luck. This starts as soon as I boot up. I don't have the install disks to run the Apple Hardware Tests.
Every forum I've looked into trying to solve the problem has the issue of people not reporting back to what their problems were. Or how they have actually fixed them. Any ideas?
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
2 件のコメント
I feel your pain. I have exact same issue and I am starting to think it is a SMC firmware issue as the AHT, and ASD diags both show no error. the fans all run OK and can be controlled manually via smc command-line.
さんによる
Take a look at THISthread so you know where I am at with my investigation.
さんによる
コメントを追加
2件の回答
最も参考になった回答
I's happened to me with iMac 24inches and first time they changed my motherboard. After a while, it's happened again and I performed a Hardwaretest. It saw the same diagnotic message : then they changed my power supply module and they fixed my problem. So now it looks good.
Kind regards
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
It would be useful to run the AHT.. I bought replacement DVD's from Apple for around $20.00AUD ea. Well worth it IMO
Your local apple store may at least test it for you free??
Either way If you post any errors for analysis it will assist
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Darren Cotta さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 1,516
