メインコンテンツにスキップ
締切られた回答
Volume down button doesn't work
Recently while changing the screen on an iPad 2 the power button flex cable got cut, so the power button wasn't working anymore. Ordered new cables. Connecting the cables and now the volume down button doesn't work. I have tried about 4-5 different cables (purchased from 2 different suppliers). The original cable volume and mute/rotation lock switch worked. But with new cables everything BUT the volume down button works.
Anybody seen anything like this? Is it possible somehow something else affects it? Can 4-5 different cables REALLY have a bad volume down?
powered off and back on. nothing.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
More than anything else, it sounds to me like the connector where the cable connects to the logic board is probably bad. If you're noticing something this consistent, it's more likely that a pin in the connector was bent, or the cables aren't making a full connection.
If the connector on the logic board is damaged, there's nothing much you can do unless you have access to a Microscope and very very fine soldering equipment.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 181
