メインコンテンツにスキップ
モデル番号 A1367/ 8, 16, 32 もしくは64 GB容量
915回答 すべてを表示
3 different screens 3 white screens
I am now on my third screen on my ipod touch in the last 2 months. First one broke but was still functional, 2nd one had a white screen did all the resets, nothing worked. The third on was strange, it worked great for 2 days and all of a sudden the screen would slowly fade to the white screen. Do a reset and it would work great for a couple of hours then the colors on the screen inverted and faded to the white screen. Took it apart again all of my connection are good and now cannot get rid of the white screen. Please Help.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
1件のコメント:
Did you do a restore with itunes?
さんによる
コメントを追加
3件の回答
Is the liquid damage indicator in the headphone jack activated? It should be white, if its been exposed to liquid then it will be red or pink. Have you tried getting different screens from different suppliers? Is the LCD connector in good shape and none of the pins are bent or missing? It sounds like it is an issue with that specific connector. Have you tried different screens from different suppliers? I have never had 3 in a row give me issues but it might be possible the supplier has a bad batch, but they most likely would have heard about it from other customers too.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
No water damage. And two different suppliers.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Try the screens you are having problems with on another 4th gen ipod touch. If they work on that one then you know its something to do with the iPod. If they don't work then you know you got some bad screens.
さんによる
コメントを追加
Hard reset it :)
このアンサーは役に立ちましたか?
スコア -1
コメントを追加
回答を追加する
jock さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 106
