How can I remove a headphone jack that broke off?
Headphone jack broke off inside the device
Google-branded tablet with a 7" screen. The device needs only prying tools and screwdrivers to fix. Model number: ME370T.
Your device should still be in warranty, even if it's a first gen Nexus... they came out in 2012, and 2013 has yet to end.
However your kind of accident has happened lots of times: you may find lots of similar questions with several hints. It happened on many devices, but there are common hints you may use. Also, remembering you'd have to be extra careful with an expensive device, you can try with a pair of thin needle nose pliers, trying carefully to grab the jack.
Failing the needle nose pliers, you could try some of this other workarounds:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 5
今までの合計 13,907
