Water from cold water dispenser is not cold.
If the compressor is running and does not shut off, then it is low on Freon
このアンサーは役に立ちましたか?
Water not cold
I can not get any water to come out the cold water push bitton. When I push the button on the right for cold water no water comes out at all.
このアンサーは役に立ちましたか?
Water is not cold from Water Dispenser. I can not hear the compressor running.
Is there a way I can check to see if the compressor is burnt-out.
Handy Man
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 7
過去 30 日: 32
今までの合計 13,835
4 件のコメント
water from cold water dispenser is not cold
David Galindo さんによる
what l can do f dispenser is not cold?
jerry tantuan さんによる
Please let me know where the fuse is???
jpagliughi@gmail.com
John Pagliughi さんによる
Oddly, the water is acceptably cold during the summer months when the temp in the kitchen is about 75. In late fall & winter temp is 70 due to heat running. I find no external thermostat / cold control as in a standard reefer. What gives?
Barry Thompson さんによる
