メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
Can not power on after replacing power button
my iphone 4s was having problem with the power button, i have to press very hard to get it to work. i got a replacement power button flex cable and replace it. but after the replacement, the power button completely stop working. I swap back the old cable/button, its not working either. What could be causing this? thanks
  • it does power on after i plug in the cable to the computer.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
There are a couple of issues. A couple times I have looked at this issue it ended up being that one or both of the screws on the power button retaining bracket were not installed. Does the button make clear clicks when depressed? It shouldn't be hard.
Check your cables for folds, tears or rips. Check the port the cable plugs into for dust, debris, or broken solder points. Is this phone still recognized by iTunes?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
cli168 さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 2
今までの合計 79
