メインコンテンツにスキップ
モデル番号A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5もしくは2.8 GHz Core i7プロセッサ
432回答 すべてを表示
HDD Fan speed 0, CPU fan speed at maximum
I tried to add a SSD, to my iMac 21.5 2011.
I followed the steps from the guides (iMac Intel 21.5" (Mid 2011) Dual Hard Drive Kit). I din't have a SATA power cable, so I used a power spitter. I took the power from the HDD and split it to the SSD.
The iMac found the SSD and its HDD, but the fans went crazy.
The optical drive fan works as it should (I left the thermal sensor). The HDD drive fan indicates 0rpm, and the CPU fan goes at full throttle.
I removed the SSD and left only the HDD. But the fans remained the same.
I also tried http://www.hddfancontrol.com/ but it's not doing anything for the fans.
Any tips or info, that would help me solve this, is appreciated.
iMac Intel 21.5" (Mid 2011) Dual Hard Drive Kitの画像
製品
$27.99
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
Try an SMC reset - your kluge may have caused problems with the EFI. Fans run at high speed by default if temp sensors report out of range or failed (your HDD fan sensor could be the cause of the fan problem). If the reset doesn't work you'll have to figure out if a fan is indeed shot.
A fan control app should work - but with one fan out you could cook you CPU so I wouldn't use one anyway.
If this answer is acceptable please remember to return and mark it.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I found the problem. I haven't connected the HDD fan to it's power socket. (>_>).
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ispas Adrian さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 886
