メインコンテンツにスキップ
The Intellivision is a video game console released by Mattel in 1979.
Can I replace the zener diode?
I was wondering if it was at all possible to tell what diodes are needed to replace the zener diodes that are in the power supply?
I have one in my intellivision that corroded apart and wasn't sure if I should try replacing it, or if I should just buy a parts intellivision and just replace the board alltogether.
*edited to add an image
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
post an image of the location and what it looks like, This may help to properly identify the parts. Use this guide to add images Adding images to an existing answer
さんによる
I am sure that replacing any parts is safer than purchasing one for parts. You may just have old parts in that one as well :-)
さんによる
コメントを追加
1 件の回答
最も参考になった回答
skyler, which one do you want to replace
Update
skyler, C9 is actually a non-polarized capacitor 0.1 uF 25V ; CR5 is a IN4001 Diode. If instead of C9 you meant CR9, that is a Zener IN746. Hope this helps, good luck.
Needs Clarification
not exactly sure where you are describing. Are you looking for the components under the heatsink? From your description, it does sound more and more like capacitors. Use a graphics editor to mark the location on your image and repost it, or use my diagram and name the designators.
このアンサーは役に立ちましたか?
スコア 3
7 件のコメント:
C9 is the zener that is out and cr5 is kinda corroded too
さんによる
do they make non-polarized capacitors that look like zener diodes? (or did they I should say)
さんによる
Not that I know off, but "C" is definitely capacitor vs "CR" which is a Diode or Silicon Rectifier
さんによる
Would you happen to know what the zener was from the codes on it? it has 104z 50v and 8208 or 8z08 it's hard to read
さんによる
The 104z could be a most likely 1N4148 switching diodes, but the 50V is confusing. You sure we are not looking at caps? Which part on your image (thanks for posting it) are you looking at?
さんによる
2件以上のコメントを表示
コメントを追加
回答を追加する
skyler さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 18
今までの合計 3,797
