メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2201回答 すべてを表示
締切られた回答
Lower Mic not working on voice memo and calls after repair
After replacing my earspeaker (with flex/power cable) the lower microphone stopped working (microphone not working during calls or voice memo).
When recording a voice memo and playing it later I can hear some clicking noises.
People who are calling me say they here noises like a fax or something.
I've tried to replace the dock connector with microphone but this didn't help.
Tried to clean all the grounds/connectors with isopropanol, didn't help.
With a headphone/microfoon connected memo and voice calls is working.
Any help/tips are welcome!
Thank you!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
The uppr mic is used for Voice Memo and Speaker Calls. First step is to clean the small pin hole at the top of iPhone next to Headphone Jack. Clean this out, use straightened small staple, air, whatever you can.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi Brad,
Thank you for your help!
Tried to clean out the small pin hole with compressed air.
No luck.
Speaker mic is working when calling also the mic is working during video capture.
Maybe some other things to try?
Thanks!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Did you ever get your problem fixed? I would be happy to know how, since I ran into the same problem recently. (Camera mic works, speakerphone works for calls and skype, but normal mic does NOT work for voice memos and calls).
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Sorry, I wasn't able to fix the problem.
さんによる
Ok thank you anyway for your reply. :)
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 2,060
