メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
締切られた回答
fast way of testing 4g 4s LCD other than installing completely
Hi There
We are a wholesale company that provides mobile phone spare parts to labs and cellular operators.
We sell a lot of iphone 4\4s LCD.
we always test our goods before supplying to our clients,
my questions is, if there is a way of testing the 4\4s LCD with completely installing the LCD to the phone?
because this method takes us a long time and can easily destroy the mainboard.
the big problem is the pressure marks on the sides of the LCD, which can be seen only in full installation.
thats why the use of testing "machine" or flex LCD extender do not help.
Would like to hear your suggestions.
Thank you very much
Raj
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi, the easiest way you will be able to test LCD's is by picking up a tester flex like the one linked below.
http://www.ebay.co.uk/itm/New-LCD-Digiti...
If you only need to test a single LCD you can attach the flexes to the motherboard without having to fully dismantle the device, make sure you put a little bit of electrical tape on the old flexes to prevent any shorting.
Regards
Tiny
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 91
