メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
Erratic touch screen iPhone 5
I smashed the screen on my iphone 5 and therefore bought the complete front panel i.e glass, digitzer and LCD all in one unit. All i needed to do was take the microphone, ear speaker and front and back camera off the old unit, fix it to the new unit and put the phone back together. It was perfect for a few days but now the Screen behaviour is erratic. It is acting like i am touching the screen but i am not. Anyone know what the problem could be?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
コメントを追加
5件の回答
最も参考になった回答
I had the exact same problem. I went to the AT&T store who told me I need to take it to the Apple Store. They also said that since my phone was more than a year old, I couldn't get a replacement, otherwise Apple would replace it for free. They also said the problem may have something to do with the screen. That's when I suddenly realized I had the screen and the LCD replaced a couple months ago, since my phone fell and the screen broke. So I called the guy who had replaced it, he came over, changed the screen and voila! It worked!
Try replacing the screen. that might work. Good luck!
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Sounds like this could be caused by a few different things.
1. Software, IOS is awful at calibration, even after a week or 2 problems can arise that weren't there to begin with.
Try reseting the device by holding both power and home buttons until the screen has gone black and the apple logo has appeared. Backing up and re installing IOS may help resolve this issue as well.
2. Shorting, any ESD (Electro Static Discharge) can cause the digitizer in the screen to act strangely i.e. ghost clicks and unresponsiveness.
Open the device and check that no screws are out of place, also check the flexes for any damage.
3. Faulty Hardware, the part that you have been supplied may be defective.
If none of steps 1,2 help contact the supplier of your screen and get them to swap a new screen with the faulty one you have been given.
Hope this helps :P
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My phone does this as well, but I've not replaced anything in it. My phone has operated perfect for the entire 24 months since I got it off my launch day order. I'm going to try a battery first in case it is somehow causing this. My battery is discharging at an accelerated pace these days and sometimes it charges extra slowly too. Also, my phone acts normal for about the first 10 minutes of usage each day and then after extended periods of non-use throughout the day as well. As for my screen, it acts like an ESD issue. I'll even see red and blue grid lines on the screen when it starts acting up. I hit the power button then immediately hit the home button and swipe it open. It will then give me about 10 seconds of regular usage before it acts crazy again. I've already bought a new phone as I can't go without, but I hope to get this one fixed and hang on to it as well.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I had bought an I Phone 5S. Two days later the screen started behaving erratically. I thought maybe it was a software problem so I took it back to the store where I bought it they guided me to an apple care centre. They told me that it was the hardware problem. I had got a defective product. They helped me out with the procedures and got a replacement for the defective product.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I've seen this problem a lot with new screens. They can often be of poor quality and have a bad digitizer. Return the screen and order another. Maybe try to disconnect, clean, and reconnect the flex cables first.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Carl さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 16,482
