メインコンテンツにスキップ
より早い処理スピードを可能にしたiPhone 3Gのアップグレード版です。このデバイスの修理は3Gと似ており、標準のドライバーと開口ツールが必要です。モデル番号 A1303 / 16 もしくは 32 GBの容量 / ブラックもしくはプラスチックの背面ケース
1500回答 すべてを表示
締切られた回答
My 3GS battery replaced and cannot be charged?
Anyone can help? I have just changed my 3GS battery from ifixit.com and everything seems to work. When I tried to charge it, the battery symbol shows a plug but not the lightning. The battery doesn't charge and is draining. Everything else works on the 3GS. I've reopened it and check the connections and they are all in place. Any solutions? Thanks so much.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
When I replaced my battery, connector #4 would not stay fully seated, so the battery wouldn't charge. I had to put a number of thick tape on top of that connector so that closing the Iphone would put pressure on the connector. So far for six months it has been working.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Connector #4 is intact, that's why there's the plug symbol. But there's no lightning symbol and the battery keeps draining.
さんによる
Sorry it didn't work. You may want to try a hard reset where you hold down the Home button and On/Off switch until you see the Apple logo. I sometimes have to do that to get my iPhone to start charging.
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 134
