Hi-res images; Can you see any problems with this logicboard?
I've almost lost faith trying to repair a water damaged MBP. The sellers have clearly ravaged the logic board for parts, now i need advice as to weather i'm wasting my time or not.
I have ordered the parts around the freehand yellow line (thanks to old turkey for the input: What are these missing parts on my logic board?)
all other yellow circles are damaged looking parts or components that look missing (ridge-like solder plates give them away)
I guess what i'm looking for is someone to tell me what parts look broken / missing and weather it's even worth trying to replace them..
many thanks.
http://postimg.org/image/g09jdeist/
http://postimg.org/image/wruuw5j1p/
http://postimg.org/image/gsc7clmzx/
http://postimg.org/image/ej7dsyrjf/
I removed part "U6630" with a lighter and tweezers.
Unless I employed a tamarin to solder the part I really dont know how to do it.
are there any guides out there to replace such a small part?
(find the 9 small solder dots in the center of the image)
この質問は役に立ちましたか?
2 件のコメント
Matt Rowlands, no issues with identifying those missing components.Total cost I would estimate somewhere in the $30 range. A question I have to you is, are you capable of fixing this board? I do not mean that in any disrespectful way, but just wanted to know. As for is it worth it, only you can answer this. It will take some work and a bit of money, and that is what you might lose if it will not work. Would I do it? Yes, just for the challenge of it:-)
oldturkey03 さんによる
as for your update on the U6630, that is what is called a BGA and needs a different approach. It needs a reflow....
oldturkey03 さんによる
