Upgrading RAM from 512 to 1G
I will be changing my RAM from 512 to 1G prior to installing Leopard.
Do I need to do anything special besides just changing the stick on the first startup?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
No the computer should see the new memory on startup and be good. Just be careful to select the proper ram for your computer. I am including links for replacing the memory and for the memory itself is case you don't have them. Good luck with your project. Ralph
Mac mini (PowerPC) RAM Replacement
[リンクされた製品が存在しない、もしくは無効: IF111-035]
このアンサーは役に立ちましたか?
Thank-you Ralf. I will give it a try this weekend.
Another question: I will purchase a wrist stap on the way home. Where should it be connected to?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 1,282
